Soo my 33s are getting wore down and spikes the interest of 35s...
my question is will a front stock dana 30 with an aussie locker handle 35s Safely? I don't want to loose an axle/ snap something going down the Interstate at 70+ mph shouldn't snap anything just free Wheeling down the highway my worry is a hairline Crack on the shaft or somethning from wheeling and then it decides to catch up with me on the highway...
slight wrench into things... I have a 5.3l ls swapped tj
My Build:
5.3l vortec
4l60e Stage 2 built trans
4.5in short arm lift
Stock np231j t case
Gear ratio 4:10
Rear axle dana 44 w/limited slip
Front axle dana 30 w/ aussie locker
Current tire
33x12.50x15 mastercraft courser mxt
We (family and i) usually do green/blue trails I don't get rowdy with it because with v8 torque something is bound to happen I usually take things pretty easy it's also my daily in the summer. I believe it has alot to do with how you drive if things are going to break I've had quite a few people tell my dana 30 won't hold up to a v8 but it has...
just curious if I should be upgrading to chromoly shafts w/30 spline ?
My Build:
5.3l vortec
Stock np231j t case
Gear ratio 4:10
Current tire
