have a set of LED pods 40W each. been running them with no issues for quite a while. each pod came with its own harness and switch however i used a Y adapter to attach both to the same harness and switch.
today i flipped them on and no worky worky. checked fuse, sure enough it was blown but it seemed odd to me, looked as if it had blown slow if that makes sense. wire had distorted to the side and melted just a small portion through the side of the fuse. I noticed it was a 5 amp, which seemed puny to me for a nice set of lights.
did the math and sure enough both lights together should draw 6.6 amps. so this seems to be the cause of the fuse blowing. It just seemed odd to me it took so long to happen. I would expect it to blow when i installed them, not a full year later.
i understand the ratings on these fuses are not exactly laboratory grade exact.
Is it possible that not only was the fuse running hot the entire time, but that it may also have been limiting current and therefore light output? I doubt it would make much difference as 1.6 amps capacity short doesn't seem like a big difference, but i was just curious.
