2006 LJ rubicon, New to me)
History: My rear locker flashes. It does not "Lock", have tested it off road,, drove in s turns,, blah blah.I've checked the pump, and air line at the Differential, 5-7psi, all good there. I've pulled the diff cover, to ensure no leaks in the air line there. I've checked the relay under hood, good. I've multimeter both sensors(the ones that screws into the Differential, that have a mushroom plunger). I'm not getting a reading at the rear. SO MY Question. I thought the locker would infact operate even if the sensor is bad, is that incorrect? My thinking is if the bladder is getting air, should engage? Also, PO re-geared to 488 thick set. It's possible the plunger was shoved in, after the carrier was put in, and they did not use the "tooth pick" method, keeping the plunger extended, so it's on the correct side. And insight, would be fantastic, thanks
