A minor detail - the screw grommets that the headlight trim ring screws go into are different 97-02 and 03-06. The early grommets fit in a slot in the tabs and the later grommets fit in a square hole. The grommets are incompatible but the headlight trim rings are the same so as long as the grille you get has the grommets your trim rings will work with either but if you get a later grille that doesn't have the screw grommets you won't be able to use the grommets that are in your early grille.
