Ok, all hooked up! Shipped the other one back, bad switch. I’ll post some pics here in a sec. It was easy
@bobthetj03. I used the handheld winch controller, cut the wire so it remained insulated. I have a Superwinch, so the three wires are in-out and power. I know that sounds weird, but there is a power line coming to the controller. Placed the insulated wire in a cable protector, went across the front, behind my new body lift mount, in behind the driver fender and up behind the washer fluid down the side and into the cab through the rubber grommet.
I have two switches mounted in teh dash, a Winch Isolator, which is just an on-off switch, a protection. It has power running directly to it from the battery, a ground and a power out. The power out goes to the Winch Rocker Switch, which is an on-off-on switch. It has a ground, an in, an out, and a power wire coming from the Winch Isolator. I had to use a Dremel and a file to cut a hole for the Rocker Switch. The Winch Isolator just replaced one of the stock blanks.
Winch will only work when you flip on the isolator. Works seamlessly
