Windshield wiper nozzle spray pattern adjustment
danof76
105
98
San Antonio, TX
#1
Not sure if it's just me or if it's just TJs in general (or at least certain years) but does anyone else's windshield wiper nozzle spray a really pitiful pattern? I'd liken the spray pattern to a squirt gun.
Just for clarification they are pointed right and appear have the right amount of power to them, but they just don't have any coverage and just spray in one spot that measures a grand total of maybe two inches around. Doesn't do me a whole lot of good especially if I need to clear off something on the top of the window, it just smudges.
Any suggestions? Any modifications, third-party or cross-compatible parts that work better? While I'm at it, does anyone have any good recommendation on wipers? The ones I have like to chatter quite a bit on their way down. Thanks!
tworley
1,330
1,250
Morrison, CO
#4
Early GM models have spray nozzles attached to the wipers themselves. Snag a few put them on your wiper arms. Its a much better coverage vs a spray from a foot and half away traveling at 65 mph. Take a look at @jjvw build thread.
Likes: jjvw
danof76
danof76
105
98
San Antonio, TX
#5
Funny because between your post and the last I (incidentally) came across that post as I was going through his build thread (which is quite awesome). I may look into that solution.
Likes: jjvw
tworley
1,330
1,250
Morrison, CO
#7
I did the same thing with mine, the junkyard I snagged the nozzles from and various hoses didnt even charge me for them. Its nice having to spray directly on the windshield and with a much wider pattern
jjvw
0-60 in 18 seconds
4,360
3,583
Colorado, USA
#10
If adjusting the pattern solves the issue of the spray not getting to the windshield at 75mph as the road mist is quickly clouding your view, then go for it. Just know that things can be better if you want or need them to be. This may be a regional thing. I don't recall having quite the same driving experiences in other parts of the country where the roads are messy.
RaymondT
480
478
Summerland, B.C.
#11
Anco 91-13 wipers.
Disconnect the nozzles and run the pump a few seconds to blow any swarf out of the lines. Use LP air to back-blow through the nozzle holes. Hook everything up and "borrow" a good-size needle from the wifes sewing kit. Adjust the two balls on each nozzle assy by rotating them using the needle as leverage. On each side, adjust one ball to spray in the upper part of the sweep and the other on the lower part, kind of a staggered pattern.
After that, they will work most awesome.
Likes: danof76
