I've installed the Windstar Air intake filter box that many have put in but am having an issue with hood clearance.
I didn't see this address in other posts so I wanted to put this out to see if anybody had a good solution.
I drilled firewall hole here:
But I'm finding that the hood impacts the filter box as you can see through this tape test and the spots on the air filter box.
I haven't seen this issue on other installs so I'm curious if anybody has been seen or dealt with this problem.
I can't see that I've got much room to grind down given the grounding bolt and spot welds.
