I bought a Jeep Wrangler TJ 2005 95K 4.0L Auto yesterday & the windshield wiper fluid does not spray. Has anyone encountered this issue before? The wipers work fine, the sprayer just doesn't work.
Same fuse, #17 25A for the 2005.I have no power at the plug, it was intermittent but stopped working completely now. The pump works great. The wipers still work, are the wipers and washer on the same fuse?
3) No fluidEither one of two things:
1) Your pump is unplugged
2) Your pump is no longer working
Not likely, but make sure your washer reservoir has 2 motor/pumps. Someone may have switched to it to a single (soft top version) at one time.I have a similar issue, except it's the rear window washer fluid. I push the button all the way down and see no fluid, but the rear windshield wiper works. I assume windshield washer pump in the front? Or as Jerry Mentioned "odds are good the water line or jets are clogged up with hard water deposits". I'll check that also. Looks like possibly Mopar part#5096343AA? I appreciate any help or guidance!
What voltage did you get at the pump connector? I am trying to figure out if my voltage is enough considering it runs on a 20amp fuse but the voltage I was getting was .13A. What are your thought?I found that I had voltage at the pump connector when the washer switch was activated. I installed a delco replacement and it works now. The delco pump has an harness adaptor included which I really don't care for, but it works. I would find a direct plug in replacement if I had to do it again (no adaptor).
EZ to do in about 15 minutes.
