1. Want to have your TJ featured as the August 2018 "Ride of the Month"? The winner will receive a $200 gift card from Metalcloak! Click here to submit a photo of your TJ. Submissions are accepted until July 20th!
    Dismiss Notice
Wire crimp tool
Discussion in 'Gear' started by StG58, Jan 9, 2018.
  1. StG58
    StG58 Backwoods Amateur
    Thread Starter
    Oct 29, 2015
    5,401
    5,323
    Orygun, the wet side...
    I need recommendations for a wire crimp tool. The SE needs some wiring repair where U-haul installed trailer wiring for the PO. It looks like they used two rocks and scotch tape. It's causing intermittent issues with flashers and turn signals.
    Also a recommendation on a small heat gun for shrink tubing would be appreciated.
    Thanks a bunch!
  2. TJ4Jim
    TJ4Jim TJ Enthusiast
    Dec 9, 2015
    986
    678
    Brookings, Oregon
    Not a big fan of crimp connectors on Jeeps as they are never sealed to the elements. I prefer to solder all connections and sealing with heat shrink.
    Bought this last year and it works great for soldering and heat shrink, I should have bought this years ago and ditched the soldering gun
    https://www.homedepot.com/p/Bernzomatic-ST500T-Auto-Ignite-Butane-Torch-335258/205495608
    Duan and StG58 like this.
  3. Chris
    Chris Administrator
    Staff Member
    Sep 28, 2015
    24,895
    14,163
    Salem, Oregon
    Glad you asked! I've been using this heat gun going on 5 years now:
    https://www.amazon.com/dp/B00EU2T8GG/?tag=wranglerorg-20
    It works for all my needs, but I mostly only use it when removing tough decals, or when using heat shrink on wiring.
    As for wire crimpers, I've probably had this thing for close to a decade now:
    https://www.amazon.com/dp/B0069TRKJ0/?tag=wranglerorg-20
    It works well, and I have zero complaints about it whatsoever.
    Basic stuff, but it's served me well for all my wiring needs (which mostly ends up being guitar wiring harnesses or Jeep wiring).
    StG58 likes this.
  4. StG58
    Thread Starter
    Oct 29, 2015
    5,401
    5,323
    Nice! Thanks for the link.
    I used to work for a company called Astro Tool. MilSpec wiring crimps for aircraft and armored vehicles. We did a lot of testing on wire termination. I found out that I do better with crimp joints.
  5. StG58
    Thread Starter
    Oct 29, 2015
    5,401
    5,323
    Thanks Chris. Looks like a good quality, basic tool.
    Chris likes this.
  6. StG58
    Thread Starter
    Oct 29, 2015
    5,401
    5,323
    Here's a selection of my current tools:
    Wire stripper(s), Buchanan terminal crimper, and an Ideal zip tie tool.
    The Buchanan is going out of adjustment, so it's getting replaced.
    We built wiring repair kits for M1 tanks and the B1-B. Really cool, but more expensive than I could afford.
    Chris likes this.
  7. Chris
    Chris Administrator
    Staff Member
    Sep 28, 2015
    24,895
    14,163
    Salem, Oregon
    Yep. Chinese made obviously, but they've both lasted me years, so I don't care.
    StG58 likes this.
  8. Chris
    Chris Administrator
    Staff Member
    Sep 28, 2015
    24,895
    14,163
    Salem, Oregon
    A zip tie tool? How does that work?
  9. StG58
    Thread Starter
    Oct 29, 2015
    5,401
    5,323
    Loop the zip tie around what you want to hook up. Set the tool for the proper tension. Squeeze the handle and the tool sets the proper MilSpec tension and cuts the tail off the zip tie. It's pretty cool, actually. Perfect zip tie every time. Not too loose, not to tight. Trimmed flush.
  10. Chris
    Chris Administrator
    Staff Member
    Sep 28, 2015
    24,895
    14,163
    Salem, Oregon
    Crazy! I always just did my zip ties by hand and then cut the end off with my clippers. I should have known they've have a tool for this.
    StG58 likes this.
  11. StG58
    Thread Starter
    Oct 29, 2015
    5,401
    5,323
    Here you go! Pictures... You just know the military has a spec for everything.
    20180109_131707.jpg 20180109_131732.jpg 20180109_131817.jpg 20180109_131837.jpg 20180109_131902.jpg
  12. Chris
    Chris Administrator
    Staff Member
    Sep 28, 2015
    24,895
    14,163
    Salem, Oregon
    Haha, this is probably what MPs carry around to cuff the bad guys, huh?
    This is like one of those tools you absolutely do not need, but you want to have just because you're a guy... and us guys like to collect tools (I'm the same way, ask my wife).
    StG58 likes this.
  13. StG58
    Thread Starter
    Oct 29, 2015
    5,401
    5,323
    Ideal Industries Cat. No. 41-990.
    Chris likes this.
  14. StG58
    Thread Starter
    Oct 29, 2015
    5,401
    5,323
    Nah, on Shore Patrol we just looped them together and hung them on our gun belt. How tight we pulled them depended on how drunk and how much of an a-hole you were.
    #14 StG58, Jan 9, 2018
  15. CodaMan
    CodaMan California Prisoner
    Mar 9, 2017
    2,333
    2,288
    Mariposa, California
    A properly crimped connector is almost always better than a soldered connector (less prone to vibration breakage). To weather proof it just heat shrink over the crimp connector.
    #15 CodaMan, Jan 9, 2018
    Kiwi TJ and StG58 like this.
  16. bobthetj03
    bobthetj03 TJ Expert
    Supporting Member Ride of the Month Winner
    Feb 3, 2017
    5,615
    5,794
    Lake County, Northern California
    StG58 and Chris like this.
  17. StG58
    Thread Starter
    Oct 29, 2015
    5,401
    5,323
    bobthetj03 likes this.
  18. skrelnik
    skrelnik TJ Enthusiast
    Jan 10, 2018
    362
    207
    CT, United States
    StG58 likes this.
  19. Doug Ayers
    Doug Ayers New Member
    Dec 9, 2017
    15
    13
    South Carolina, United States
    StG58 likes this.
  20. ac_
    ac_ zombicon
    Jun 15, 2017
    2,240
    2,082
    AZ, United States
Share This Page
