Wiring for an e-locker
LJRubicon
Spring Hill, FL, United States
I have a Sterling rear axle in my LJ. I ordered a factory eLocker from Ford because it fits all years Sterlings and the only eLocker available. Anyone have any idea what size Cable Gland I would get to get wire thru housing? Should I use plastic or aluminum ones or it doesn't matter? Aluminum sounds better to me but not sure if it makes a difference.
You can grind a slot as wide as the wires and just put Rtv in the slot along with your differential cover on top of it. No need to drill the housing.
Reactions: Noxid
