If your lift came with a frame side track bar drop bracket to go with the dpa, you have to remove that too. Make sure the alignment is correct and then try rotating the tires.Only adjusted for steering center.
Everything is not tight.Replaced the drop pitman arm with factory one. Only adjusted for steering center. No wobble before just bump steer, no bump steer but wobble at 50 mph and above. 3 “ lift. 38k miles everything tight, what the heck?
Daisy chain. Don't be surprised when you change the tie rod at the pitman you srill have issues.I had my son work the wheel and did see a small amount of up and down movement of the tie Rod end at pitman. No drop bracket on track bar. I did order an adjustable track bar, doing one thing at a time here. Would adjusting the tie Rod to make the steering wheel straight effect my alignment? I am replacing the tie Rod end today. It seems odd I went from a tight front end with bump steer to no bump steer with major wobble just changing the pitman. It’s literally not drivable above 50.
Don't forget the trackbar too!!!Daisy chain. Don't be surprised when you change the tie rod at the pitman you srill have issues.
Once that is tight the next weakest link will show itself if they exist.
Got a link to that crown set up?I replaced a dropped pitman arm for bump steer, then replaced the track bar for wobble said screw it and ordered the crown heavy duty steering setup and replaced everything!!!!!! No more bump steer, no more wobble and lots of peace of mind!!!!!
@Chris Has a link on here, I want to say it was from AmazonGot a link to that crown set up?
There it is!!!!!
