If you're front seats are feeling a bit wobbly in the front, it's likely due to the bushing being worn out. There are two per seat. There's someone (maybe someone from this site) selling a set for $25 on etsy. Not a terrible price. It also includes the roller, which isn't necessary to replace unless you just want a better looking one.
But, if you have access to a 3D printer, here's a print ready .stl file you can use to print the bushing yourself. You may be tempted to use ABS, but PLA is actually pretty good for this application as PLA is harder than ABS. Or, if you have access to higher end materials a carbon fiber blend will be even better. Better still, if you have some IGUS iglide filament, that would be ideal. Fairly spendy stuff and somewhat specialized (Igus uses it to make linear bearings).
Print a bunch and replace them as it wears out. Surprising how this little bushing affects ride quality.
