Half Rebuilding a NP231J due to suspecting odd noises. Transfer case
Symptoms that led me to rebuild:
- Cycling Woosh sound: Mostly in 4hi and 2lo during acceleration
- Cycling Woosh sound while coasting sometimes.
- Loud grinding noise while decelerating in 2nd gear. (engine braking)
- Input shaft on t-case was leaking atf
Replaced in the past: U-joints, transmission mount, fluid changes.
Total time to do this repair: Under 5 hours
General steps:
Raised jeep on jack stands, supported transmission with jack, removed transmission mount bolts, supported skid plate with jack, removed skid plate, removed front and rear drive shaft, supported front shaft to keep out of way, removed two electrical plugs, removed rubber vent tube, disconnected Tcase selector, removed transmission mount plate, drained t-case fluid, supported t-case with transmission jack, removed the bolts holding the t-case to the transmission, removed t-case, watched some fluid leak out of transmission.
Put t-case on bench, realized the dust cover is something I didn’t plan for, removed speedo gear, removed bolts from housing, cracked case using special screw driver slots, tried to remove dust cover again, then figured out I would remove the front output yoke, but I didn’t have the 1.25” socket, but I did have a 32mm, got it off easy with an impact wrench, pulled the case apart.
Inspected everything, looked amazing, removed the input shaft cover and found RTV over everything including the bearing, removed the snap ring and then found the bogus bearing. The input shaft bearing was not lubricated as RTV filled the lube hole.
Videos can be seen here:
Sound of T-Case Outside of Jeep
Sound of T-Case in the Jeep
Bad Bearing (Input shaft)
Replaced the seal, replaced the bearing, RTV’d it back up. Noticed the output bearing on the front yoke looked bad so I replaced that too. All other bearings looked great. Chain seemed fine, but I replaced it anyway.
Getting it back together wasn’t too bad, but it was harder due to not disassembling the rear output shaft. I put the rtv on, then secured the chain in the rear housing along with the front out put shaft in the top half, and finessed it onto the lower half. I then prayed it went together correctly. It did. I tested it by shifting and spinning shafts.
Then i had to repair some nut-serts in the frame, used the transmission jack to lift it back into place, re-connected all and test drove.
So many sounds are gone!
Tips:
I purchased the chain and rebuild kit from:
Rebuild Kit NP231J
Chain NP231j
Amazon Parts:
Pliers
Bearing Driver
I needed to have a way to get the dust cover off. (fail on my part)
Ratcheting wrenches are the best thing ever invented.
