Guys I had an issue with Jeep overheating several weeks ago and went on Chris' faq and started ordering parts to update the cooling system. I tried driving it after this happened to see if maybe the thermostat was stuck or something and it worked fine. So I know that I have been procrastinating getting the cooling system overhauled and flirting with it overheating again and all that goes with that. Well I ran it a number of times with no issue but today I was picking it up from the local shop that did some gear work for me and it overheated right as I pulled into my office.
What I noticed was the fan wasn't running at all which tells me it is bad and likely a big contributor to the issue I am sure.
So the question is when the engine is running and warm (i.e. after it cooled down from overheating but still warm) it appears the fan doesn't run at all. I tried turining it by hand and I could turn it but not easily. It felt very restricted and rough to turn although it will turn. Any thoughts on it? Clutch? other?
I just need to get home but don't want to do any damage doing that. It is about 10 minutes home mostly highways. Should I run the heater and go for it or leave it until it cools way down tonight and come get it?
I tried to attach a video of of it running but fan not turning. The engine was quite warm and it was quite hot outside.
