FRONT AXLES
Dana 30 (181 mm) - 1997-2006
* Front axle used on all TJs except the Rubicon model
* Stock gear ratio options = 3.07, 3.55, 3.73, 4.10, 4.56
* Carrier break = 3.55 / 3.73
* Open carrier - no Trac-Lok limited slip option
* Ring gear diameter = 7.2"
* Ring gear bolts = (10) 3/8 x 20 RH
* Low pinion (short pinion)
* Pinion shaft diameter = 1.376"
* Pinion shaft spline count = 26
* Axle shaft diameter = 1.18"
* Axle shaft spline count = 27 both inner and outer
* Axle shaft u-joints = 5-760x / 5-297x
* WMS-WMS = approximately 60.5"
* 5 on 4.5" bolt pattern
Dana 44 Front Axle (216 mm) - 2003-2006 (Rubicon Models Only)
* Standard front axle used on all Rubicon model TJs
* 4.10 gears
* Tru-Lok selectable pneumatic locker - open differential when unlocked
* Ring gear diameter = 8.5"
* Ring gear bolts = (10) 7/16" x ??
* Low pinion
* Axle shaft diameter = 1.31"
* Axle shaft spline count = 30 inner / 27 outer
Note: The outer axle shafts, unit bearings (hubs), knuckles, and brakes are the same as those found on the TJ Dana 30.
REAR AXLES
Dana 35 (194mm) - 1997-2006
* Standard rear axle used on all TJs except the Rubicon model
* Stock gear ratio options = 3.07, 3.55, 3.73, 4.11, 4.56
* Carrier break = 3.31 / 3.55
* Optional Trac-Lok limited slip differential
* Ring gear diameter = 7.5625"
* Ring gear bolts = (8) 3/8 x 24 RH - NOTE: 7/16" x 20 RH used on later model TJs
* Low pinion
* Pinion shaft diameter = 1.406"
Rubber pressed-in fill plug
Dana 44 (216mm) - 1997-2006
* Optional rear axle used on 6 cyl models except the Rubicon model
* Stock gear ratio options - 3.55 (97 only), 3.73
* Carrier Break = 3.73 / 3.92
* Standard Trac-Lok limited slip differential on early model TJs / Optional on later model TJs
* Ring gear bolts = (10) 3/8 x 24 RH - Note: 7/16" x 20 RH used on later model TJs
* Low pinion
* Available for the 1997 and newer 4.0L TJs only after 7/7/96
Threaded 3/8" fill plug
Dana 44 (216 mm) - 2003-2006 (Rubicon Models Only)
* Standard rear axle used on all Rubicon model TJs
* 4.10 gears
* Tru-Lok selectable pneumatic locker - limited slip differential when unlocked
* Low pinion
