Didn't the Ford explorer with the 8.8 and Jeep Grand Cherokee use the same brakes? Might help if you get desperate and start hunting things down in the junkyard
The 8.8 versions have the Set 20 big bearing Ford bolt pattern. Doable, not exactly a walk in the park. Jeep Liberty and Grand do have a version that bolts up. JGC of the ZJ era needs the center hole enlarged to fit over the set 10 bearing set. Liberty is the same as TJ for the years that work.
