2001 TJ 4.0 Auto
I’ve been dealing with a misfire for a while now and it’s time to resort to some direct help from the community. I’ve been following forum advice as much as possible through this process but I’m still stuck. Through everything I’ve done the misfire has remained on 6, P0306 code. Slightly rough at idle when cold smooths after warming. Generally don’t feel the miss when driving until 1500ish RPM, then it’s rough all the way through. If I put distance on it more cylinders will pick up a miss, usually 5 come second. Seems to be worse after warming up.
So. Many. Fixes. Attempted before coming here to post about my woes! I’ve probably gone through some parts that were more than necessary but I just want this misfire to go away. I’ll list everything I’ve tried in the order I tried:
Time for an LS swap?
- Spark plugs - Autolite iridium and champion coppers, just to be sure.
- Coil rail - Autozone as I didn’t want to wait 3 months for the Mopar part.
- Crank position sensor - Mopar part
- Fuel pump - Delphi part
- Injectors - https://www.ksuspensionfab.com/store/p71/Remanufactured:_4_Port_Upgrade_Injectors_YJ/LJ/TJ.html#/
- Battery - Big ass Odyssey. Needed this anyway for some electronics upgrades
- Compression checked out - don’t have values, took it to my local trusted mechanic for this.
- PCM - wranglerfix.com
- Cleaned and checked grounds
- 2/1 Downstream O2 sensor - NTK part - replaced exhaust and sensors last year. Tried a new one recently just in case
