IF none of the other forum members can provide you the answer; you could contact @mrblaine for the information you need.
They are all roughly the same. The rotor has to have the center bore opened up to fit the bearing hub and then the hole sizes have to be fixed (most always) to accept the press in wheel studs.I’ve done some searching and cannot seem to find this easily but if one has the Black Magic Big Brake kit what is required to make the Yukon hub kit fit?
I recall some had to have some machine work done but I can’t recall exactly what it was.
Any help is appreciated.
Doing a search for my question and came upon this thread (same questions I had a few weeks ago).
If I do the Yukon 07 kit I'd also install equivalent thickness spacers in the rear (or close).
Current new wheels are 3.75" BS to fit 15-16" BMB BBK. That BS would be reduced to approximately 3" with the hub kit.
Do I NEED wheels with more BS (4.5") to prevent excessive positive scrub or am I overthinking the importance of that?
I would like to keep the current new wheels.
Still waffling over the damn 16" beadlocks that happen to be 4.5" BS and the expense of E rated tires or a complete new set of wheels to match my 15" tires.
Specifics depend on which kit and which brake kit. We do them all from the 15/16 to the 17" kit with both the WU-07 and 08 small and large hub conversions. We've even done the Solid Axle version and a few WJ conversions to work with the 08. (don't do that, it isn't cheap)
I’m running the 15” kit and can manage the machining for the rotors and redrilling for the studs.
Thanks a bunch for the info!
