2001 Sahara 82,000 miles, driven 2,000 miles a year since 2008, no upgrades. Do have larger P265/70 R16 Goodyear Wrangler Kevlar All-Terrains on stock rims with K&N air filter.
- 4 weeks back it was driven on low fluid because of leak... would shake once engaged in drive on first start of the day.
- Leak has been fixed (hose on radiator)
- No shake when engaging in park
- HOWEVER now intermittently it will hesitate when driving off the line in DRIVE at a stop light But WILL NOT hesitate if I put it in 1st gear.
- Snap-on Computer Feedback: "Drain back relief valve kit is available to help alleviate problem of delayed trans gear engagement. See REF#C1020"
- Also seems to NOT consistently shift form 1st into 2nd OR 2nd into 3rd (this is new). NOT terrible but is noticeable
- Responsiveness in acceleration is ALL OVER the place... great then nothing.
- Last; sometimes when stopping at a light, if I press on the gas slightly then let off... I get a bump feel from the rear, as if someone rear-ended me.
- Random Question... could an over oiled K&N Filter be causing any issues?
