So I have a 2000 Jeep Wrangler with a 2.5l 4 cylinder and for the last 2 months I have been struggling with getting the cat monitor to ready. So to start off at the beginning, I went to get my Jeep smogged and it failed due to the cat monitor not being ready and after doing some research I came to the conclusion that my 20 year old converter was no longer working. It was reading about the same temperature upstream and downstream, using a thermal gun. I then replaced that along with the 2 O2 sensors (NTK) since they hadn’t been replaced since I have owned the vehicle (2013). I did some driving and tried to perform various drive cycles and to my dismay none of them worked. Took it back to the smog station to see if they could get the monitor to ready up and they couldn’t because the MAP sensor wouldn’t stay in the correct range for the monitor to begin it’s test. We came to the conclusion that is was due to me having 35 inch tires and that my speedometer difference was too great from what it actually should be for the monitor to run so I ordered the correct speedo gear and replaced it. Brought it back to the smog station and they ran 2 different drive cycles 3 times each, for a total of 6 attempts and never could get it to run the monitor. I have taken temperature readings since I put the new cat on and upstream reads around 400-500 degrees after getting off the freeway and downstream reads anywhere from 750-900 so I know the cat is good. I read the 02 sensors on my scanner and the upstream sensor goes up and down like a wave like normal and downstream is as steady as a steal rod. I never once had a CEL for a cat or 02 sensors, or for that matter any emissions related code. So my next step is the dealer, but before I do that I figured I should ask here and see if anyone has any suggestions. Out of options and frustrated. I see lots of people with the same problem but it looks like a lot of people have found solutions, I have not.
