I recently picked up a 2006 Rubicon and noticed that the front right speaker doesn't always work. Wiggling the center console makes it work again. Me thinks that either the 12 pin sub connector, the sub amp, or a wire near the center console is grounding out but before I pull the console I want to know if my theory is correct to check there. At first, I thought it was just the old stock radio but as I said shaking the console brings the speaker back to life.
Did my research in the service manuals and saw that the factory radio runs to a connector behind the steering wheel and splices off to the individual speakers and all 4 feeds go to subwoofer together thru a 12 pin connector. I'm guessing somewhere in the console or amp is where my issue is originating from as the amp apparently does some equalization and its affecting pin 1 and 2 (gray and gray/brown wire).
I need to know 2 things:
If the amp is the issue, I will eventually replace the unit with a small powered sub tapping the remote wire in the harness, running RCA from a new aftermarket head unit, and running new 12v from the battery. Saw some options on that in other threads.
- Am I possibly on the right track checking there? I don't think its the stock radio causing this as its easily duplicated just moving the console a bit.
- If I don't find a frayed/loose/dirty wire there that fixes the problem, does disconnecting the sub entirely (and covering the connector with tape) affect the other 4 speaker locations?
