I am looking for suggestions or recommendations on what make or style of locker rear end to use. I do not want an air locker.
The having to service the arb every 5000 miles or so is a real turn off.Because air is so troublesome?
What service is that?The having to service the arb every 5000 miles or so is a real turn off.
@Jerry Bransford , I seem to remember a post of yours regarding ARB vs ox cable that had some good info, can’t find it thoughI run a detroit in my 8.8 but it doesn't see much road time. When I do drive on the road all I notice is a loud clunk taking turns every once in a while. Selectable is more ideal for road rigs. Electric locker is an easier install with just needing a switch. I like the ox locker since if the manual or electric ever fails you can use the lockaway device to lock the axle.
huh??The having to service the arb every 5000 miles or so is a real turn off.
I thought that about my wich, If I don't already spool it once a month then I probably don't need it, but I haven't gotten stuck since I got it, and I actually need to go spool it for December. I guess it's one of those things, If you have it, you won't get stuck.I guess my thinking is that if I am not using my Air Locker at least every 6 months, probably don't need a locker.
One of my favorite things to do is attempt an obstacle with both lockers off for the first couple of times (sans very sketchy sections where a slip/slide can be a big problem or result in significant body damage)...True that. Maybe I am in minority, but when I am off-road, I almost always have my rear locker activated since I figured better to already be locked than wait until I get in a situation and then lock it.
Lunchbox lockers are not a good choice for the rear axle. #1 they're weaker since they have to be small enough to fit into the carrier. #2 because they're extremely poorly behaved when on the street. Front-mounted lunchbox lockers are fine on the street, it's when they're in the rear axle that their behavior is not good.Lunchbox and deal with the tire squeal when you punch it?
I'm not saying lockers are cheating, but they can definitely take out some of the finesse and lower the skill-requirement in the technical terrain. I actually have two buddies who have monster trail rigs (buggies) who also have small rigs (one is a flatty and the other is a 2.5L YJ on 31"s and open diffs) for a "challenge". Both have even said (independently) that they find themselves wheeling the smaller rigs more and more simply for the higher level of overall enjoyment.
^^^^True that. Maybe I am in minority, but when I am off-road, I almost always have my rear locker activated since I figured better to already be locked than wait until I get in a situation and then lock it.
