Plastic intake hose from air box to throttle body
Injector harness or repair kit (mine isn’t burned from the 3 cylinder forward)
Throttle cable
Injectors
Pcv kit
New hood. Thanks in advance.
I've got a set of injectors from my '04 I'd let go for cheap, shipping's on you. They have about 107k on them.View attachment 290078So like the headline says my 2000 jeep caught fire this morning. Looks like I need a few parts. If anyone has suggestions on sources that would be great. I called Daveys jeeps and they are two weeks out. The following is what I need.
Throttle cable
Injectors
Pcv kit
bummer!The fire was caused by what looks like a mouse nest between the 3rd and 4th cylinder not totally uncommon from what I hear. What sucks is I have the heat shield for it and always keep that area clean. It just finally happened. Could have been worse!
Always a good ideas to carry a small portable extinguisher. I’m glad it wasn’t worse. Good luck moving forwardFor everyone else that needs to protect from this, how did you extinguish fire?
And if you use a dry powder type extinguisher make damn sure you was all that powder shit off asap.Always a good ideas to carry a small portable extinguisher. I’m glad it wasn’t worse. Good luck moving forward
You must be fire prone.Has anyone used a element in a fire? I carry two in the TJ but also carry a 2.5lb outside on the tire rack.
I used a hose and split it to hold the element
Nick was mentioning a couple weeks ago he ignited one to become familiar with it @NickgsjeepHas anyone used a element in a fire? I carry two in the TJ but also carry a 2.5lb outside on the tire rack.
Haha. It’s like my hi lift Jack. Have it and never need it.You must be fire prone.
Glad to here that! Luck favors the prepared.Thanks everyone so far. I will PM anyone if I need some parts. I happened to put my fire out with a fire extinguisher from inside the shop I work in. Funny how you can’t find them when you need them tho.
