Rickwhoo
I want to add a high beam switch on the floor in my TJ. Anyone do this yet? I miss this.
Also going to add a foot rest. Anyone do that?
Why? Do your fingers get tired using the one you have?I want to add a high beam switch on the floor in my TJ. Anyone do this yet?
No, I just like it. I had it in my old cars when I was young and want it back.Why? Do your fingers get tired using the one you have?![]()
I know where there is a bench seat when you're get to that point. Doesn't even have any head rests...I plan on it right after I complete my foot-actuated parking brake and six-on-the-tree conversions.
It can be done. I did it on an old 89 chevy pick up years ago.The headlight power is just a simple battery circuit that goes to the headlight function in the multifunction switch. The part that is trouble is that the multifunction switch determines whether it's sending that power out the low beam circuit or the high beam circuit.
In an older vehicle, maybe even 97-02 TJs that has the old headlight switch on the dash, the headlight power is just a simple power wire to the headlight switch, then the headlight switch sends that to a dimmer switch (operated by a turn signal stalk usually, or in the case of what you want, the switch on the floor).
Since on your 2005 this is all accomplished by the single multifunction switch, I don't see how you can accomplish what you are wanting unless you rewire to your own added headlight switch and then wire the floor switch to the output of your own headlight switch. right now the current multifunction switch is already sending the power straight to either filament (high or low) so you need to remove that from the equation.
Maybe you can crack open the multifunction switch and figure out how to get a simple "headlight on" power wire coming out of it down to the floor switch and bypass the multifunction switch portion, but I'm with the others, that's a lot of work for a something like this. Wouldn't be worth it to me personally.
If it's a 60/40 split ...I know where there is a bench seat when you're get to that point. Doesn't even have any head rests...
Really complete the look and feel.
you missed what I said. An 89 Chevy doesn’t have anywhere close to the same circuitry as a TJ with a multifunction switch. The Chevy has the same old school separate headlight and dimmer switch I am talking about, which would be easy because you just run the wiring to the original dimmer switch over to the floor switch instead. In one of those the dimmer switch is just mounted to the steering column and operated by the high beam stalk with a rod. In that truck you would just need to extend the wires at that switch down to the floor switch instead.It can be done. I did it on an old 89 chevy pick up years ago.
Now you're talking up stupid...Why not put in a foot actuated starter switch too? Really old trucks had those. Put it right beside the foot actuated dimmer. Hit them both at the same time. Vacuum wipers are great . . . . going to do this mod right after the power steering is removed.
This is how I drove my last two years of high school, and when I was home my first 3 years during college. Only the starter was on the right (next to the round foot rest) and the dimmer was on the left, outboard the clutch.Why not put in a foot actuated starter switch too? Really old trucks had those. Put it right beside the foot actuated dimmer. Hit them both at the same time. Vacuum wipers are great . . . . going to do this mod right after the power steering is removed.
I would love to do the parking brake mod. Would give tremendous space for a larger console and/or move the cupholders to be more in the middle.I plan on it right after I complete my foot-actuated parking brake and six-on-the-tree conversions.
