Can I just replace my spider gears?
BoPaul
NY
My spider gears are toast. I don't have thousands to throw at it, would I be able to change just the spider gears or is there more problems going on. Its not a daily driver and when I do drive it, it's only about 20 miles round trip
mine were the same. i just replaced the spider gears with a yukon kit. plan on draining it after a year and rechecking them. ordered kit from amazon it was around $100 and took about 3 hours to swap out IIRC, not real hard to do !
Easy, no gear setup required for the spider gears. I'd run a conventional GL-5 gear lube for the new gears and for the it next gear lube change too to help reduce the heat while they work harden together.
While changing the spider gears would be easy process; you will need to THOROUGHLY clean (spray out) the inside of the housing, the gear set and bearing/races with BrakeKleen or similar product to ensure more damage does not occur.
You need to do a thorough examination of the axles splines and carrier housing since there is a question you need to ask yourself;
WHAT caused this to happen ?
I'm not really sure how this happened. They're original and the jeep has 215,670 miles so I'm hoping that it's from wear but not likely. I don't beat on it (even the clutch is original) and it's not a daily driver anymore. I just started noticing a chattering noise when taking off to a turn. No noises while driving straight or when it's cold. As soon as the rear got hot I'd hear them. I did find a couple chunks on the bottom and mostly metal flake everywhere. I do have a Zone 4 inch lift and I used the kit to pitch the axle like they instructed to, so I'm hoping that's not the cause. Thanks for you help guys, much appreciated
