Damn that under hood light sucks. I tried just replacing the bulb with an LED bulb, but the lens and the location are just not right, so let's make something better.
I purchased a 12" LED strip off eBay, it came with a switch, but I decided not to use it. Since I like the K.I.S.S. method of doing things, and I like the way the stock gravity switch works ... let's just use it.
I popped the lens cover off and removed the bulb. I added terminal lugs to the LED strip's wires and connected them to the contacts in the stock switch and popped the lens cover back on.
I routed the wires through the hood, removed the backing from the 3M adhesive strip that was included with the LED strip and stuck it to the hood ... and Wa-Lah ... LIGHT!
Took all of 30 minutes and $15.
Now I could actually do some work under there in the dark if I needed to.
