My 2001 TJ didn't come with fog lamps, so the "plug 'n play" option is not an option for the Quadratech fog lamps I just purchased. I can handle the soldering end of things without too much difficulty, but in trying to figure out where I'm going to get power from, I came across a confusing thing. Hoping some TJ electrical system guru might be able to help me out
The Power Distribution Center shows fuse #19, and specifically connection #23, as the wire that would normally run to a fog lamp relay, and then on through the circuit and eventually to the lamps themselves. I assumed this spot would be empty, seeing as my Jeep didn't come with fog lamps. But lo and behold there IS a 20amp fuse in #19, and there IS a wire coming off of connection #23, which disappears into the wiring harness.
But what's also weird is that the manual shows the color of the wire that would normally be coming out of #23 for the fog lights, as white with an orange tracer (WT/OR). But the wire that's there now appears to be pink with a green (or possibly light green, or maybe grey?) tracer.
Any idea what---if anything---this wire runs to/powers? I looked all over the wiring harness diagrams for an wire that fits that color scheme, but no luck
Ultimately I'm looking for a good hot source (somewhere under to dash, if possible) to wire these up to an aftermarket switch, and thought maybe this pink/grey guy might be a candidate, if it's not being used, especially since it's already fused. If there isn't one available I can just home-run to the battery and put a fuse inline, no sweat, but if something is there I'd like to take advantage of it
Any and all thoughts and ideas are appreciated!
