The idler pulley
There is an idler pulley, and a tensioner pulley. You need to rotate the tensioner pulley back/down to slip the belt off.
The tensioner pulley is under the alternator in this picture.
The idler pulley
Working on it now, have a slight problem. The idler pulley won’t loosen enough for me to take the belt off. The belt is still very tight with the pulley loosened all the way. What do I do?
You are missing something obvious or the belt would have never been able to be installed.
That’s what I thought, but I’ve been staring at it for 20 minutes now
Look down behind the bracket with the slot in it and make sure the threaded block is all the way at the end of the adjuster bolt.
Is this the tensioning pulley and its adjusting bolt at the bottom in this setup?
If this is it, are you loosening the pulley or tensioner (highlighted)
I loosened it so much that the pulley came off. So the pulley is all the way off, and the belt is still tight
The pulley moves in that slot by turning the tensioner bolt. Did you turn the bolt on top of the bracket to move the pulley all the way down in the slot?
Yes, I did that first. All the way. That wasn’t enough, so I took the pulley off in its entirety hoping that that would loosen it a bit more. Still tight
Cut the belt and buy the correct one.
That’s what I was planning on
Saw a pretty neat trick a while back on holding the thermostat in place. Loop a wire or string through the top of the thermostat the side that faces the hose. Pull the wire through the hose hole and pull it tight till you get it in place and snug the bolts down. You should have at this point two wires out the hose hole end, pull one side removing to wire and then torque bolts down as needed.
You do understand that if you have to cut it with the pulley removed that there is something really odd going on, right? Typically with that set up, when the pulley is all the way at the lower end of the slot, the belt will just sneak over it but once in place is not very tight at all. For it to still be too tight to remove means they did something almost impossible to install it.
