Hello all,
Regretfully, my first post here is one for help, rather than an introduction. I recently started bringing my '99 Wrangler back to life. It has been pretty dormant, either in storage or buried in a small garage behind a motorcycle for the past 5+ years.
In the process of a bolt pattern conversion and moving the lugs on my rear Superior axle shafts, I noticed one of my rear brake caliper pistons was cracked. This was a "junkyard conversion" from a '96 Grand Cherokee, and I've been running everything as I pulled it 8 years ago.
I bought new calipers/pads for an '03 Rubicon instead of from a '96 ZJ so that I could use abutment clips and the TJ pads. In turn, I got rotors for an '03 as well.
My question, and I promise I did search, has anyone had issues with the rotors not fitting their axle shafts? These are Superior shafts, just regular Dana 44, not a Super 44 kit.
But after re-drilling the new rotor, I could not fit it onto the axle shaft. Upon comparing the rotors, you can see the new one I re-drilled has a lip on the inside, with a much smaller inner diameter.
I know I converted the bolt pattern and re-drilled the rotors, but I see no interference with the wheel studs, it is the axle shaft flange hitting the inside of the rotor. Do I need to use a ZJ rotor for the rear? Can I grind the inside of the rotor to make room, or is there something I need to look for when purchasing new rotors for a TJ?
Thank you!
Hopefully as I get more into my Jeep "refresh," I can start to contribute a little more around here!
Thank you!
