The cam bolts that could be used on early 97 to mid-99 to slightly adjust the caster angle disappeared in mid-99. I thought they were completely gone after that but I just learned they're stock in the 2006 again. When were they reintroduced?
Thanks, and the '04 had them from the factory right?I can confirm that 04 and 05 have them
Now I’m a bit confused. I know the 04 and 05 have the cam slot lower control arm mounts but I don’t remember there being a special cam bolt. I think both of mine just had a normal bolt with an oversized washer.
My 2000 has them. My question is can they be rotated and if so what does it change?
95 or 06?I just looked and my ‘95 doesn’t have them.
The ‘06 FSM says “if” the vehicle has the cam bolt. Maybe it was optional but not stock on every Jeep.
