I've been waiting to put out a post as I'm still hunting the issue. Been documenting in my build thread but I'm ready to reach out in the technical forum for ideas.
I finished up install of a Currie/Savvy 4" suspension with JJ at all control arms and track bars. I also installed Currie CurrectLync, Front Anti-Rock, and new Woody's DS (front & rear).
Upon first drive after those upgrades, the Jeep was all over the road (a terror to drive). I was in a rush (had to get cleared of emissions testing or lose my registration) so I missed getting the trackbars torqued and also found that I hadn't seated one of the JJ snap rings when I greased the balls before install.
I re-set this JJ.
I had the wife help me on an alignment with the tires on, using the lugs. After the first drive, I decided to get some aluminum to try again — Confirmed the wife helped get it where I wanted it...
So this past weekend I had the time to:
Symptoms:
I found it interesting that it felt good (not great) yesterday. I had it up to 70-75 MPH on a 20+ mile trip. It was ok starting on the way to work and then just got worse. I couldn't drive above 50 MPH without worry the oscillating would bring the ass-end around on me.
Like I said - I plan to work on torquing everything on the suspension again. But I would really like any suggestions of things to look out for while I do.
I re-set this JJ.
- Torque upper & lower control arms to Currie-provided spec
- Torque track bars (front & rear) to spec at the axle and frame
- Anti-Rock to spec (at the bar/arms & the links at the axle) — Best effort on the links at the arms bc I couldn't fit a socket
- Torqued Rear swaybar (w/ new bushings) at axle, and both ends of the links to spec
- Lubed the Currectlync joints (tightened up the steering afterwards)
- Retorqued Currectlync
Symptoms:
- It's ok under 30 MPH on straight roads
- It feels like it wants to start oscillating left and right to the point that it will have the rear end come around. (This is Not a death wobble or tire vibe — so far as I can tell) Very prominent above 30 MPH or on windy roads.
- It feels like the rear end is moving around. (That's what I'm feeling but I don't want to ignore something off what I 'feel')
- It pulls to the right when I change gears (manual)
- Under power, the oscillating/darty feeling is most pronounced. I can cruise from 40MPH to a stop and it feels fine under cruising & braking.
- To stay in lane, I feel like I need to 'nurse it' back to center if it gets a little left or right, or risk the ass end coming around.
- Best I can describe scenarios are above. Other words that come to mind when I drive it: Darty, Floaty, Oscillating, Rear Steer, Boaty
