Driveline vibration when hauling
harpflora
Toronto Canada
Hi, I have a 2.5 inch rough country lift on my Jeep TJ.
I had driveline vibrations so I added a 1 inch transfer case drop and it runs fine, no vibrations when it’s just me in the Jeep
However, when I’m hauling 2 passengers in the backseat and have a cargo carrier rack attached on the tow hitch with some items in it. I then get a driveline vibration from 80km/h to 95km/h. It goes away past 100km/h
Could this mean I need to reduce to a 0.5 inch transfer case drop? I assume with the added weight when hauling the Jeep sqauts a little more and changes the driveline angles?
I assume with the added weight when hauling the Jeep squats a little more and changes the driveline angles?
You are correct.
I would reduce the transfer case drop spacer to 3/4” and recreate the weight of the passengers and rack; then check for driveline vibrations.
The best way would be to measure the driveshaft and pinion angles with the loaded weight and adjust to get about a 0* difference.
Reactions: bucky
