The hose doesn't appear bad, just the rubber connector. Here's a better picture. The connector itself is brittle and seems to be cracked. Also when I ran a smoke test, smoke came out of the hole it's connected to. I'm also hearing a whistle with the throttle so I'm thinking it could be the bad rubber connector.Is the hose bad? You may need to replace the whole thing. Are you talking about one of these lines?
https://wranglertjforum.com/threads/am-i-missing-a-hose-on-my-4-0-intake-manifold.9242/
Does anyone know what part number the rubber elbow for this vacuum line on the 4.0 intake manifold is (see picture) and where I can buy a new one? Thanks!
LukeH did you ever find a resoultion for this?? I am having the same issue. I even tried to go to the dealership and they told me new parts for this are no longer available (manufacturing is discontinued). I have looked through several online sources and can not find a solution.
I'm having the same issue with the same elbow. The problem with replacing it with some kind of tubing is that the two ends have different diameters; the little tube coming out of the intake manifold is a smaller diameter than the tube that is connected to the bottom of the elbow. Any new ideas?
My 4.0 doesn’t have that line, but I just replaced a couple other vacuum lines. Mine are brittle and snapped when I pulled my motor. The eBay silicone tube has a lot of flex. I was able to use it when the diameters at each end were very different. I just ordered the diameter for the small side and it stretched over the big side.
Thanks! Can you reply with a link to a source for that?
Electrical tape worked for a year with no evap codes.
