Ever have a knocking noise that you chased and chased and basically lost your mind? I have!
I do feel somewhat stupid because there were things I should have done as actual testing instead of just throwing money at the potential problem, but I did find a few other things that needed to addressed along the way.
What I replaced:
All 3 tie rod ends
Track bar
Upper/lower ball joints
L/R Axle u joints
Upper steering shaft
Lower steering shaft
Steering gearbox
Wheel hub assembly
Front L/R sway bar links
Front sway bar bushings
Rear sway bar bushings
Rear L/R sway bar links
I did need new rear sway bar bushings, I could push the bar up and down with ease. Also found 2 tie rod ends that were shot. After going through 2 sets of front sway bar links I was convinced it was them and after disconnecting the sway bar links and not having any noise. (Someone on here told me to do that. - thank you for that)
After reading a lot about sway bar links I found about the importance of sway bar angles. I feel dumb for not being able to pinpoint it earlier but it’s part of the learning process I suppose.
I have a 2 inch suspension lift. JKS to the rescue! I bought the ones for 2.6 - 6 inch lift, installed them and drove around. Still had a tiny knock and I saw I still was below 10 degrees so I raised them to a little over 12 and it was magic. Not only is the knocking gone, it handles better.
What I replaced:
All 3 tie rod ends
Track bar
L/R Axle u joints
Steering gearbox
Wheel hub assembly
