W wkelley70 Member Original poster Supporting Member Joined Aug 28, 2018 Messages 90 Location Eagle, ID Jun 12, 2024 #1 Which brand of front axle upper control arm bushings is recommended for a DANA 30 (2006 LJ)? Last edited: Jun 12, 2024
TheBoogieman Disturbed Supporting Member Joined Jan 1, 2019 Messages 16,701 Location Charlottesville, VA Jun 13, 2024 #2 Last edited: Jun 13, 2024 Reactions: JMT, Granite, wkelley70 and 1 other person
astjp2 TJ Guru Supporting Member Joined Aug 22, 2018 Messages 6,842 Location Utah and Alaska Jun 13, 2024 #3 I went to Jeep and bought JL bushings for $18 each Reactions: Obi-Wan and wkelley70
Obi-Wan In my experience, there's no such thing as luck. Supporting Member Joined Apr 6, 2022 Messages 610 Location Tatooine, Outer Rim Jun 13, 2024 #4 TheBoogieman said: View attachment 534150 View attachment 534156 Click to expand... I spent all this time making you a new sticker last year and you still wont show it off. I'm hurt I tell ya. Reactions: TheBoogieman
voodooridr TJ Addict Supporting Member Joined Oct 15, 2020 Messages 2,591 Location North Idaho Sep 17, 2024 #5 Does this bushing look right for the front axle end of the upper control arms? https://www.summitracing.com/parts/...1252637918853&utm_content=GSAPI+5ba2959840c41
astjp2 TJ Guru Supporting Member Joined Aug 22, 2018 Messages 6,842 Location Utah and Alaska Sep 18, 2024 #6 Just get some from the dealership, use LJ bushings and bigger bolts
voodooridr TJ Addict Supporting Member Joined Oct 15, 2020 Messages 2,591 Location North Idaho Sep 18, 2024 #7 @astjp2 LJ or JL? Bigger bolts would be a plus Last edited: Sep 18, 2024
astjp2 TJ Guru Supporting Member Joined Aug 22, 2018 Messages 6,842 Location Utah and Alaska Sep 19, 2024 #8 Either will fit, I just put lj in the hp30
Y yassi2000TJ New Member Joined Dec 1, 2022 Messages 6 Location Miami,FL Jul 28, 2025 #9 astjp2 said: I went to Jeep and bought JL bushings for $18 each Click to expand... Do you have a part number by any chance?
astjp2 TJ Guru Supporting Member Joined Aug 22, 2018 Messages 6,842 Location Utah and Alaska Jul 28, 2025 #10 yassi2000TJ said: Do you have a part number by any chance? Click to expand... just go to moparpartsoverstock.com and search the part
CJ with a TJ TJ Enthusiast Joined May 13, 2025 Messages 159 Location Boston, MA Jul 29, 2025 #11 I just grabbed a Crown from CarParts.com for $17
astjp2 TJ Guru Supporting Member Joined Aug 22, 2018 Messages 6,842 Location Utah and Alaska Jul 30, 2025 #12 Mopar was $18 and probably at the dealership close by. The mopar is a dual durometer.
