Hi all, so I’ve been dealing with a P0306 code for several months now and I’ve now reached the conclusion that I believe it’s a problem with the PCM and I need it either fixed or replaced. I’ve switched injectors #5 and #6 to see if the issue followed, it changed nothing, I’ve done a fuel pressure test on the line and it was good, did a compression test and it looked good, switched spark plugs 3 times, changed the coil rail, checked for vacuum leaks and checked the wiring with a test light and it was lighting up. Also changed the cam position sensor and still having the same code so I believe the PCM just needs to be repaired. If @Wranglerfix could provide some insight I would greatly appreciate it.
