Went to a restaurant for lunch, everything was working great. came out and started the Jeep, no blower on any speed. Tried turning the key slightly back, tried re-starting engine, nothing. Will be starting troubleshooting probably in the AM, it's 104F out there right now and I can't get it into the garage, no room. Been searching old threads and printed out my wiring diagram. Looks like the relay trigger gets switched on at the dash thru fuse 8 and energizes the coil which feeds the blower motor from the 40 amp fuse in the PDC and the speeds are controlled by the ground signal routed thru the various resistor taps.
If it turns out I need the dash controls are the aftermarket ones any good or Mopar only?
edit: Correction, it's not 104F, it's 106F.
