TJ fiberglass upper half door help
SilverLJR
Edgewood Washington
I just bought some hard fiberglass upper half doors I have no clue what brand they are. They also didn't come with any hardware and they don't just drop in like normal ones.
Any help identifying or what I need to buy for hardware would be great.
Thanks!
I believe from looking at them you need the brand specific lower half as well.
You can probably get a hardware kit from bulldog. They have threaded inserts that go into the half doors
Their weatherstripping and hardware kits both worked for the mystery hard uppers i fixed up recently.they look like yours.the foam underneath needs changed for broader support though.they wobble too much.
Their weatherstripping and hardware kits both worked for the mystery hard uppers i fixed up recently.they look like yours.the foam underneath needs changed for broader support though.they wobble too much.View attachment 544026
What ^^^^ he said...
Here's an example of a kit available from Rally Tops
https://www.rallytops.com/product/jeep-half-door-installation-kit/?utm_source=Google Shopping&utm_campaign=Rallytops&utm_medium=cpc&utm_term=38216&gad_source=1&gclid=CjwKCAjwnei0BhB-EiwAA2xuBqsZfwVgCy3LAPD9a13yF0JMak-Bdrrd9y-FSTkqcemkqABZCSOr2BoCOA0QAvD_BwE
Here's Bull Dawg's kit
https://www.bulldawgmfg.com/shop/St...lnVptmSucW94xUe_LEwpiwobQ1KvU5SRoCAuMQAvD_BwE
Reactions: Rickyd
Did you find a solution to the wobbling? I just picked a set of these up in great condition. I popped them on the doors (without the hardware) and they seem to fit very snug
I haven't worked it since putting them on the doors.it only drives around town and slow on trails. Hasn't been enough of a problem to do anything about it.A strip of high density foam should do the trick
