Pilot Shaft Bushing in 03 TJ?
OldDustyTJ03
Carlsbad, NM
Pulled the transmission yesterday on my 03’ to replace the clutch and noticed an oilite bronze pilot shaft bushing inside the crankshaft instead of a bearing. The bronze bushing fell right out, which might explain some of the noises I was hearing.
Any guess why I would have a bushing instead of a bearing? To the best of my knowledge this is the original motor/tranny.
Should I go back in with a bearing or another oilite bushing? My Luk clutch kit came with a bearing and everything a read on the net suggests I should have a bearing instead of bushing.
Wrong section but I'd guess based on the damage to the bearing adapter that the original bearing died, wallowed out the bushing hole, and then was replaced poorly with a bronze flange bearing. Or they tried to remove the bearing adapter, messed it up, couldn't get it out and then stuck the flange bearing in.
Hopefully you know to get a new one with a bearing in it.
Reactions: Spike Strip
That’s exactly what I was thinking. I’m assuming after the original bearing failed, the PO tried to pull the bushing out and couldn’t and decided to cut corners and use the bronze adapter instead. I can see gouge marks on the bushing where it looks like the PO tried to pull it out with a puller of some variety and couldn't. The bushing and bronze adapter are both wallowed out pretty good.
I just wanted to make sure I was doing the right thing by going back in with new bushing/bearing instead of another bronze adapter. The fun part is going to be trying to get that bushing out of the crankshaft.
Weld a nut over the hole, go in with a bolt with enough threads or threads and a spacer in the crank recess and jack it out. Works every single time.
Good idea! I have a small hobby mig welder from HF. I'm no expert welder, but maybe I can do good enough to weld a nut on the bushing. If not, I was also thinking about drilling a couple small holes into the bushing and running a screws in just enough to hook a slide hammer onto and try popping it out.
I have done the drill and tap before, welding is more funner.
