Still no word from UCF. Called Wednesday and today no answer. Left VM no return call. Just sent sales an email. Order was placed Jan 8th.
Went scouting for trash. Did 125 miles of FS roads and a little freeway. Vibrations aren't much worse than before. Drives 75 no issues.
Had a high idle issue. Found the vacuum line from the intake to the evap solenoid had pulled loose installing the motor mounts and spacer.
Found a 26' Tahoe RV and a Pioneer pickup camper. Plus five more RV debris piles... essentially dumped parts leftover from scraping frames.
And a Honda Fit on its roof, sans engine and transmission. And a couple of large, occupied encampments.
Yesterday I fixed my driver's door latch...screws were bottoming out before tightening on the door. Added a washer and a lock washer, lubed everything up and reassembled. Works great now...no more leaning into the door to open.
View attachment 587761View attachment 587762View attachment 587764
Is that state or federal land? I'm surprised they don't get run off by the authorities
Federal. US Forest Service. According to the FS (our local FS folks) they need guidance from the department of justice and their office of council to decide how to interpret and enforce laws... it's a schedule of rules. They do this review every two years. The last one was late 23...before the Grants Pass decision about reasonable accomodations overruled the Boise decision that you can't crminialze homeless.
Bottom line our one LEO has been instructed by national Forest Service policy to do nothing about unhoused until more guidance is received.
We've spent at least a hundred grand last year in FS funding...252,000 lbs of trash and 43 vehicles...25 of those required asbestos tests aka RVs. This number is roughly 1/3 to 1/6th of what for profit contractors would charge.
If you extrapolated those numbers nationwide...and understand that the FS explicitly states they don't have an unhoused problem or illegal dumping problem...and even when we clean these sites they're still tons of micro trash, defaced trees, campsites, trees, roads.
I have a pet theory that every major fire in the west in the last twenty years or so was started by unhoused folks.
The costs are staggering.
And we're the worst solution to this problem...
Spent about four hours in the shop. Cut an inch out of my fuel tank skid. Changed the speedo gear... wasn't that far off from my previous gear for 33s but since the o-ring appeared to be leaking seemed to be the Jeep gods sending me a message. Knocked a ton of fine dirt and sand down. Drove down to the logging scales...4380 lbs...down 20 lbs from either the mostly empty tank or the dirt I removed.
View attachment 586487View attachment 586488View attachment 586489View attachment 586490View attachment 586491View attachment 586492View attachment 586493View attachment 586494View attachment 586495
Such a smart mod! I might take you up on your offer to help me do the same!
Today...only issue with my home made mid pipe was the v band clamp and rotating it 180 got me clearance. Need a tig welder. Want to make some modifications. Good enough for now.
View attachment 590679View attachment 590680View attachment 590681View attachment 590682
It was DEI exhaust wrap that I should have painted but didn't.
Did it fray on its own or was that power washing,etc?
