He a fallout fan?
Never heard of it fallout. If you are referring to the tattoo on his hand it is a Mechanical Cog and the “symbol “ of his Navy rate of Engineman.
He a fallout fan?
@JMT what ya think of last night’s videos? He goes underway today and back Wednesday and I’m headed down to move him in to a townhouse with a small garage. That should help with progress. I will be bringing his motorcycle down so that’ll give him another set of wheels if the Jeep is down again.
I think that t-case is going for a rebuild.![]()
Why is the output shaft rotating freely in 2wd?
IDK. It would be nice if he could do the test with it on jackstands.
If he's on base isn't there an auto shop? There was on most of the bases I was on... And some had parking if your vehicle was inop for a few days or weeks.
I did an engine swap & installed a lift kit in one.
I believe the output shaft is free in 2wd because he has the 6-speed in neutral and e-brake applied.
I would use the base shop bits it’s been closed for the last couple months for remodeling or something.
Even if the transmission was in N it shouldn’t turn freely
Really? That would mean if my transmission is in neutral and e-brake is OFF I wouldn’t be able to push the Jeep. Call me crazy but ….
It’s out. Not as easy as yall make it out to be but it’s still out. View attachment 604551
Ya'll need to learn how to adjust the parking brake.
Why. It works fine. What’s the issue
Adjusted properly, it sets hard about 3 clicks up off the floor.Why. It works fine. What’s the issue
If you adjust the shoes correctly and then the cable it will only pull up about half that much.
My luck is the same. I'd buy a case with the same problem as the one I'm trying to fix 9 out of 10 times.“new” case installed. Noise is still there.
