Was not ticking this morning. Son drove 1 mi to school this morning & 1 mi home this afternoon. Heard it when he was pulling up the driveway. 156,620 mi.
Went outside and started it up. Loud tick on initial start up then went away.
Have owned the Jeep for 2 years & that was the first time it's sounded like that. Want to make sure it's nothing serious that's going to leave my 16-yr-old stranded.
Pretty sure it is a cracked piston skirt.
Check out Dex Jeeps on you tube. He has some great videos on 4.0 noises and how to fix them. More than likely it's 1 or more cracked piston skirts. The noise can get better after warm up as materials have expanded enough to quiet things down.
Well, there is no way on this earth that a dodgy lifter can eat that much oil (any oil?) but a cracked piston that's also hurt the oil control ring? Yep, that will do it. Might not be the only issue but its a darned easy one to fix in your driveway with only a basic set of tools and a bit of effort.Changed the oil & only 2 qts of black oil came out. We changed the oil just 1,700 mi ago. So there's another issue I need to figure out. There are no leaks anywhere, no spots on the driveway.
<edited> you don't need to splurge on a full set of rods and pistons from Dex either. Pull your rods and pistons - push out the old wrist pins and spend maybe $200 on a new set of pistons and rings from Rock Auto. Another $200 for fresh bearings, head gasket and an oil pan gasket and you've got a nearly complete rebuild. Will it be as good as a fully rebuilt motor? Maybe not, but the damned things are bullet proof anyway and for $400 and a sunday afternoon what have you got to lose?
Does it matter which brand? Rock Auto has Enginetech @ $118 or Sealed Power at $167 (set of 6 pistons). Same thing with the rings, prices vary between $39 - $89.
