Turn signal light in instrument cluster stopped working
I have the same problem. On my 99 Jeep Cherokee the right and left turm lights work fine but the dashboard the right indicator stopped working (left inicator still works}. Any resolutions to these issues?
Have you had any solution?
Same issue as others! Right indicator on dash went out, external bulbs and sound working as intended. Right side also out when using hazards
I'm having this same problem in a 1998 XJ. All the blinkers work on the exterior of the vehicle. But the right turn signal indicator on the dash does not work with either the blinkers or the 4 ways. It randomly will work but usually not. If anyone has a solution please post.
Take the gauge cluster out and examine the connection for the turn signal light. If it works sometimes but doesn't work other times, that suggests that the connection is bad / corroded.
