:oops: You sacrificed a C body didn't you??? :( :LOL: Lots of the big girls lost their driveline to make little cars fun. How was that 727 with a 4.10? I'm guessing in town was great, but the highway, probably not. :sneaky:
Probably depends on how loose a convertor is being run .
60's cars were very under tired. good point.
It's interesting, and I know it had a lot to do with the "long and low" styling that took over in the '60s, but the tires really did drop kind of drastically late 50s and didn't get back to "big" until fairly recently when everyone started running 18"+ wheels.
The big cars of the '60s ran 28-29" tall tires, which was pretty much a standard size/height up until that point, but the smaller cars started running 24-26" tall tires.
I can't see the final sale price.
Apparently it didn't sell, bid up to $1.2 schmill...
https://www.classic.com/veh/1965-shelby-cobra-289-dragonsnake-csx2427-vnmENDn/
:D
It was an ex-quarter mile car. No window mechanisms, just thin plexiglass windows held up with a single strap (per window). No heater, carpet, or seats other than the driver's seat. And it was a factory A-body 8.75 in there, by the way. As for the 4.11s, it would wind that 273 up tight. And did you know that the 273 Commando had solid lifter cams and adjustable rockers? 'Tis true. I've owned two of the 273 Commandos (the other was a '65 Dart with a 4-speed). The '68 Dart had a '67 Commando in it, as I recall. Fun car. I paid $250 for it, as the guy was getting out of drag racing. Man, them were the days...:cool:
I had a '67 Dart with a slant-six in it that ran 13" rims, and whatever diameter tires they came with. It still blows my mind to think of some of the '60s cars that ran 13" rims. MoPar had 'em, obviously, but I believe the Chevy II did as well, and the Ford Falcon, too. I believe the first couple of years of Gremlins and Hornets had 'em too, but that was in the '70s.
Anyone following the Bugatti rebuild? I haven't but watched Cooper's video on it and it's an interesting situation they have created.
  • Wow
Reactions: BlueC
I'm not very knowledgeable about the A-bodies. That's surprising you could get a 8.75 in there from the factory. Was it part of some special performance or "heavy duty" package?
Reactions: Squatch
First I've seen of that. That's an expensive rock and a hard spot to be in. I did read about a guy trying to replace a broken headlight a few years ago. They wanted $45-50,000 for a single headlight assembly. So.... :sneaky:
Standard fare was an 8.25, but starting in '67, the 8.75 was available as an option, and was standard in performance packages that had either the 340 or a big-block in it. I think in '73, however, the 8.75 was gone for the A-bodies, and they returned to only having the 8.25 available. I want to say that the '73 340 cars were detuned, and only running 360 heads and a different crank than earlier years, and thus were not as harsh on the rear axles, hence the return to the 8.25. However, it's been a lot of years since I was involved with them, so some of my info may be slightly off.
Two words, "Mini Miglia"...
Powered by a 1,293cc A-Series engine, it produces around 130bhp, which, allied to a tiny kerbweight of 660kg, means it can blast from 0-60mph in only 4.5 seconds. And despite having four gears, it’s still capable of a 125mph top speed. The distinctive whine of the straight-cut gears is a famous racing Mini trait.
The tiny 10-inch wheels are shod in slick Dunlop tyres and sit proud of the bodywork, while bulging plastic wheelarches cover them. And with its ultra-stiff suspension and low ride height, the taut Miglia hops around, carrying huge speed through corners. The cars run flat-out at many circuits.
I must have one. :p
