2000 TJ Fuel Line Fittings
bbaudoin1981
Louisiana
I purchased a new set of hard fuel lines for the TJ back in September 2025 from SS Tubes (Fine Lines). Just got around to looking into getting everything changed.
The original hard line and soft line (hose) from the tank were cut and a rubber hose placed in between and secured with hose clamps. A lot of research later, decided to go the route of replacing the hard lines and replacing the fuel tank hose as well as the hose up to the fuel rail.
The russell EFI fittings purchased do not fit the 5/16 hardline. They bottom out and do not come anywhere close to securing in the plastic retainer.
SS Tubes (Fine Lines) Part Number WGL0356ASS
Russell Stainless Steel Fuel Hose Part Number 651111
Russell Fuel Rail Fitting Part Number 640850 - 3/8 in. x -6 AN
Russell Fuel Rail Fitting Part Number 640860 - 5/16 in x -6 AN
Am I missing something? Why would these fittings bottom out and not fit?
I wrote up a resources post about how to make a new fuel line. Can't find it. Let me keep looking.
That would be great. As mentioned before previous owner cut the fuel hose from the tank to the hard line. I am trying to replace the entire fuel line from the tank to the fuel rail. A previous thread I found said the Russell fittings in the pictures I provided would work, but they bottom out way before they even come close to the retainer clip.
I am trying to replace the hose from the tank to the hard line. I was going to use the Russell 651111 hose and use these fittings to do so.
Also want to replace on the fuel rail side also.
I contacted SS tubes and they called this morning. They said they have never seen the fittings that I was trying to use. They mentioned a different EFI fitting with O Rings inside and a threaded retainer. I purchased some this morning so waiting for them to come in and will see if I have any more success with those.
Not sure if I am doing something wrong or if the hard line I purchased is just not correct.
For reference my TJ is the 4.0
Covered some of it 😔 n my build thread:
You basically need three Dorman parts and a caulk gun to press them together.
3/8 to 5/16 for the tank side:
https://www.amazon.com/gp/aw/d/B000E35WJW?tag=wranglerorg-20
5/16 to 5/16 for the line side:
https://www.amazon.com/Dorman-800-080-5-Fuel-Line-Connector/dp/B00A19LHXE?tag=wranglerorg-20
5/16 nylon fuel line:
https://www.amazon.com/gp/aw/d/B000E323IA?tag=wranglerorg-20
Video on how to do it:
View: https://youtu.be/33xJxkVVU08?si=m9Tu4v3uSaVX5npz
View: %5BURL%5Dhttps://youtu.be/33xJxkVVU08?si=m9Tu4v3uSaVX5npz[/URL]
Same concept I am trying to accomplish with the fittings I have. The fittings just do not fit the hard fuel line. Not sure why.
Ah I think I see the issue.
With the part you have you should remove the plastic clip.
You should have a locking nut like this one from Racetronix.
The part I have now is a push on connector with the plastic retaining clip. The part I ordered this morning has the locking nut like the one you have pictured. I am hoping this solves the problem. The part I do not understand is why the female side of the fitting I currently have bottoms out on the fuel line and doesn't allow me to insert it anymore onto the fuel line. It is almost like either the fuel line is not manufactured correctly or the fitting is not manufactured correctly. I have two fittings that came with the hose and two additional fittings and all of them do the same thing. I also have a -6AN male by 3/8 female fitting for the fuel tank side that attaches to the fuel pump on the tank. I tried the 3/8 fitting thinking maybe they sent 3/8 line instead of 5/16, but the 3/8 fitting is way too big. So either the 5/16 fuel line they sent is not manufactured correctly or the 5/16 fittings I received from Summit made by Russell are not manufactured correctly.
Reactions: macleanflood
Ordered new fittings last week. Same result. The fittings do not fit on the flared end of the hard fuel line. It appears that maybe the flared end of the fuel line is not flared correctly. Anyone with any insight as to why i cannot get any of these fittings to work correctly your input would be greatly appreciated.
Maybe it's 3/8 fuel line?
You've got the nut on the correct position in the first and third picture. Not the second...but I think you know that.
I checked it with 3/8 fuel line fittings and they are way too loose. It is 5/16 line, but I think the flaring is incorrect. When I put the threaded fitting on the unflared side there is a little bit of play. When I place it on the flared side (picture that is in the incorrect position only for reference) there is almost no play. This is why I measured with calipers and there is a difference in size between the non flared and flared side of the fuel line. I think that is where I am running into trouble. I contacted SS tubes fine lines again and I am awaiting their response. Only think I can see is that the flare when manufactured is incorrect.
It looks to me like this is just way too long.
Edit: I do see what you mean about it being too big at the flared end after paying attention to your measurements. .317 is big if it’s a 5/16 adapter. Idk.
5/16" is .312-.313. They have definitely changed the diameter where it goes into the o-ring side of the fitting and not much you can do except get them to fix it. If you need, I can measure the OEM SS line in the same place for them to use as a reference if they are confused.
On a side note, the fact that Jeep used the short flex hose from the pump to the hard line as an adapter has always confused me. Pump quick disconnect is 3/8" and the hard line is 5/16". Very odd but it works.
Itchy, I put the threaded side on this portion just to see if it would fit over the fuel line. This part of the fitting goes on the left side of the flare. The other part of the fuel fitting slides over this side. There are two rubber O Rings that seal the fuel line on this side and then this threaded portion threads into it to secure it. If you look at my above pictures, this side of the flare is bigger than the fuel line. It seems to me that the flaring is incorrect. I could be wrong, but that is what I am leaning towards. See picture below of how the fitting is supposed to go together. The fitting bottoms out and I cannot slide it down onto the fuel line to be able to thread the retainer side onto it. Hope that makes any kind of sense to understand....lol
mrblaine, appreciate the reply. I saw a few threads that you commented and was hoping you would see this one to give me some advice. I really think they just made a bad flare on this set of lines. I agree I do not understand why it goes from 3/8 to 5/16 and unfortunately I cannot find any OEM replacement items, so I am trying to just get everything replaced with something. I think I am headed in the right direction, I just need to get the correct sizing on the line for the fittings to work properly. I am waiting on SS tubes to reply to me so I will definitely report back with everything once I get an answer.
There is not much information that I can find on replacing the entire fuel line from tank to fuel rail which is what I am trying to accomplish.
