2005 Jeep Wrangler Rubicon $17,000.00 Lewisville, TX
Wildman
Over Analyzer Extraordinaire & Attention Whore
Staff Member
In the hills of WA
PRICE DROP |
2005 TJ Rubicon |
One-Tons |
40s |
Garage Kept |
$17,000Price dropped to $17,000 for a quick sale — well below comparable built TJs.
Garage kept since ownership — never parked outside.
79,800 original miles.
Clean title.
This is a properly built TJ Rubicon, not a thrown-together project.
Built with quality components and set up the right way for serious crawling.
If you know what it takes to build one like this, you know this is a deal.⸻
Build Highlights:
• Dana 60 Front (4.88 gears, Zip Locker)
• Dana 60 Rear (4.88 gears, ARB)
• Custom 3-Link / 4-Link setup
• ARTEC trusses front & rear
• Tom Woods 1350 driveshafts (F/R)
• PSC hydro assist steering
• 6” lift
• Nitto 40” Trail Grapplers
• KMC 20” wheels
• WARN 9000 lb winch
• MetalCloak fenders & rock sliders
• Custom front bumper w/ stinger
• VX floor shifter (RAD Designs)⸻
Important:
• True off-road build — not stock, not a daily driver, but I do daily drive it to work sometimes and it’s great.
• Built for crawling and enthusiast ownership
Private Group.. Must Join to see.
Jeep TJ/LJ Buy sell trade page
https://www.facebook.com/commerce/listing/981686174281824/?media_id=0&ref=share_attachment
While I normally wouldn’t trust anyone that owns a business with Fit in the title. Does make sense that he needs to liquidate after opening a gym and going bankrupt.
The 4.88s would be my bigger concern. I wouldn’t want to daily mine with 5.38s but it’s not miserable at 70. With the Rubi case it’s probably fine crawling.
There's so many things about that rig that look miserable.
I guess for a dedicated trail rig it might be find, I just wouldn't want to drive it anywhere but the trail. Also, all that work and no coilovers?
Reactions: GATORB8
But the sweet MC fenders more than make up for all of that!
Looks like coilovers front only. The only shot I saw of the rear looked like Bilstein monotube.
Not sure what Dana 60 means, could be aftermarket or junkyard axles. At that price, I'd figure junkyard since aftermarket axles alone would be close to $17K. With 4.88, probably be better with 37's. Possibly built for 35's originally.
It's still on slinky springs front & rear....
My guess is Junkyard Dana 60's since most would tell you Dynatrac or Currie or Rockjock or Fusion or ???? if they were aftermarket.
Reactions: suicideking
I messaged him about the axles. His reply:
'The rear is a Dana at the front is from an F250.'
Doesn't really explain what the rear is, but close enough.
A Dana 60 rear isn’t a one ton axle I thought
Do a quick search...... A Dana 60 was used in some 1 ton trucks...
New and Used Dana 60 Axles, Complete Rears For Sale | TPI
Yes, the Dana 60 was extensively used as a rear axle in trucks from the late 1950s onward, particularly in 3/4-ton and some 1-ton Ford, Chevrolet, GMC, and Dodge pickups. Known for durability, these rear Dana 60s are popular for heavy-duty applications, often featuring full-floating designs and 8-on-6.5 inch bolt patterns.
He lowered it to $15K
Also, going back through the build, it’s set up with a 4L60E automatic with a gated shifter and overdrive. Original was a six speed manual.Transfer case is the Rubicon 4:1 setup.Axles are 4.88 geared front and rear —Dana 60s with a Zip locker up front and ARB in the rear.
  • USA Proud
Reactions: John Cooper
