No...that is a front axle only thingIs there a hub nut on the Dana 44? Something like a 36mm under a cotter pin?
Thanks for the clarification Jerry. I couldn't remember if they needed a 1/2" or 9/16" socket.You just need that 1/2" socket on an extension on the 3/8" ratchet wrench as discussed earlier.
Thanks, I got confused because of a video I watched where they were doing a front. And I’m assuming the brake caliper removal is also a 1/2”. I’m bringing some other tools just in case. And I don’t have a slide hammer, so if necessary I’m going to turn the disc around, put three lugs on loosely and pull it off that way, I hope! Thanks again, not questioning your advice.You just need that 1/2" socket on an extension on the 3/8" ratchet wrench as discussed earlier.
Great idea. I’ll probably get in the diff anyway.To avoid fluid loss just Tilt the axle up on the side you are pulling. Do em one at a time and you won't have a mess.
There must have been a time
when we could have said no.
Chirp, chirp, chirp!Score. Could just run it welded and let people look at you funny in parking lots
Now I’ll be able to wheel over those concrete parking stops without worrying about breaking my turd!Rot, rot, rot thru the mall parking lot. You'll be cool!
