Hey y'all - I'm relatively new to working on these TJ's and got mine a few months ago. I was swapping all the fluids on it and decided to do the rear diff clutch packs since I was in there on my Dana 35. Long story short, I couldn't get it back together and ended up buying a new, already assembled carrier and popped it in there. Came with new bearings. After re-assembling with friction modifier in the fluid for a while, something's definitely off while driving.
Starting from a stop often produces this grinding/rattling noise, more pronounced when turning at slow speeds. Worst is when I shift from reverse to first so the gears are loaded in the other direction. Usually lasts a few seconds of sounding bad then quiets down and drives straight just fine. Pretty sure I need to open the diff back up but trying to get an idea of what to look for. I checked the lash and paint pattern when reassembling last time and didn't see anything concerning, though it was the first time I'd tried to do that.
I'll also add that my tranny grinds a bit sometimes and I'm worried about that as well, that could be another problem source. Getting into 2nd grinds pretty frequently, especially down-shifting to 2nd. It grinds hard every time and sounds terrible. 3rd can also grind getting into it as well. I'm wondering if those synchros are bad or something, I'm super scared of working on a transmission. I swapped that fluid and was hoping that would help, but it hasn't seemed to.
Manual 1997 5-speed with the AX-15 transmission, 3" lift on 33's. Has ~170k miles on it.
