I bought this RME knowing it needed an engine. So I found a good donor motor close by. It’s got the 6 speed manual so I replaced the clutch/pressure plate, flywheel, clutch fork, pivot ball, release bearing, front bearing retainer, master and slave cylinder. So that’s all good. I completed the engine swap last week and it runs amazing. But has a rear main seal leak. I knew I should have replaced it but didn’t because the guy I bought it from claimed he just replaced it and the oil pan gasket looks new. Oh well not too bad a job after the fact. Parts ordered and will complete the work in the next day or 2. And I put the soft top on it also.
