Has anyone painted there Moab wheels? I am thinking of painting mine a gunmetal gray and was just wondering how well they would hold up.
It can definitely be done well. @Ranger_b0b has the technique down to an art form.Has anyone painted there Moab wheels? I am thinking of painting mine a gunmetal gray and was just wondering how well they would hold up.
Yup...I painted mine same color...Has anyone painted there Moab wheels? I am thinking of painting mine a gunmetal gray and was just wondering how well they would hold up.
Pretty well. They have a couple marks on them from playing in the rocks and my bike carrier has done a number to the spare, but normal driving they will last a long time. The bonus is that when you paint them like this, you know the color so touchups are only a Q-Tip away!That is what I'm wanting to do. Those look great! how are the holding up?
Ok, so I was reading from your post on these wheels and I think I read that powered coating does something to aluminum wheels? I was planning on getting them powered coated.
So, the factory wheels are powder primed. The theory I heard is that they calculated the coating process into the heat treatment of the wheel. Having them done again is supposed to age them (make them brittle). I don't know for sure that. Lots of guys have them done...I'm just comfortable enough painting them that I chose to do it that way.
I did read on the AEV forum that my wheels specifically would have issues if they were powder coated again.
Ok, thanks for the info on that. I may call and talk to a coating company and see what they have to say. I know that powered coating is going to be tougher.
Like this https://www.eastwood.com/ew-rally-wheel-paint-charcoal-aerosol-12-oz.htmlPowder coating is not tougher, that’s a myth and hype. It’s more about the proper prep and resins in the paint itself. For example, if you go with a 2K Ceramic paint it has a lot more resins in it. It will be very hard compared to other paints. Try something like Eastwoods. Now, as for getting the right color, that’s another issue.
Nice. /Exactly. And just follow the application. Prep by scuffing the surface, then wipe down with alcohol and lint fredcloth until it comes off clean, spray with self-etching primer, light coats, then your Eastwood’s and clear coat if you want. Will be tough
Got it and less then a $100 bucks. ThanksNice. /Exactly. And just follow the application. Prep by scuffing the surface, then wipe down with alcohol and lint fredcloth until it comes off clean, spray with self-etching primer, light coats, then your Eastwood’s and clear coat if you want. Will be tough
